RE: KIT BUILDERS-HOW DO YOU TAPER AILERONS OR ELEVATORS FROM FLAT STOCK????
Something I do is to ca a small piece of spruce ,1/16th or 3/32nds square,to the back of the surface and then file it down with a combination rasp, using the flat side. It gave me a hard surface that kept it from tapering too much, and created a dent-resistant surface when I was through.
