RE: Need help IDing this engine..
When you call fox, you might want to order some "Dukes fuel" it is a all castor fuel and is perfect for the two engines you have there. The fox you have is a iron piston type and it will not live with synthetic lube. Since you say it has good compression, someone probably already ran it with the proper fuel and did'nt ruin it. Enjoy.
