RE: Newbi here looking for advice
hey... i ve just made my first foamie!! its an x 31! please help me figure out what power system i need for it
motor,speed controller,and battery!!! PLEASEE my planes weight is about 280 grams without the electronics.
its a park flyer.
ive found this set up.. will it work?? or fry up the electronics???
motor
1)hacker a 20 m- max powerrange is 150w
rpm/volt is 1130
2)iam using a 30 amp ecs ( more than required)
3 )the battery iam using is 910mah/3s/11.1 v
the motor company recommends using a 20 amp ecs for which a 7.4 v battery is good enough right??
but iam thinking i ll re use this stuff in other bigger planes ... so should i go in for the higher ones??
PLEASEREPLY
THANKS
