RCU Forums - View Single Post - Sig Mid Star 40 Build Thread
Old 07-18-2010 | 05:56 AM
Sukhoi_Madness's Avatar
Sukhoi_Madness
Default RE: Sig Mid Star 40 Build Thread
Some more progress –
I’m going to use the 5th wing bay from the centre for the aileron servos. I’m going to add a doubler to the wing rib either side of the servo bay – the last airframe I built with dual aileron servos was a 4 star 60 and I can’t remember what the structure looked like, but I feel with the rear spar being balsa I could do with a little extra strength in that area. Plus it’ll get me thinking about how this airplane may be built into a twin at some point.
The doublers (pictured) have been made form one of the scrap pieces of light ply from the punch outs in the fuse sides.
I realise these where removed in the first place to lighten the airplane – but I’m sure with the size of this wing and a .45 up front a few extra ounces across the whole dual aileron modification is going to make little difference to how it flys.
I’ve also started installing the shear webs.
(NB: I’m hoping around the build steps a little to be able to continue building while I wait for parts to dry – this is a bad practice if you’re contemplating your first build)
ID:	1469500   Click image for larger version
ID:	1469501   Click image for larger version
ID:	1469502   Click image for larger version
ID:	1469503   Click image for larger version
