i have a satgraph 2
look at the pdf this the page on SATA
http://sata.com/index.php?id=satagraph2&L=1
<div class="padding-17"><p class="headline_black">SATAgraph™ 2</p><p class="overview">SATA precision airbrush gun</p><p class="shortdescription">May be used with gravity or siphon cup - your choice.</p></div><div class="px-sc-tabs"><table cellspacing="0" cellpadding="0"> <tbody> <tr> <td id="tab_16392_1" class="px-tab-act" onclick="toggleTab(16392,1)">Product information</td> <td id="tab_16392_2" class="px-tab" onclick="toggleTab(16392,2)">Paint application chart</td> <td id="tab_16392_3" class="px-tab" onclick="toggleTab(16392,3)">Technical details</td> <td id="tab_16392_4" class="px-tab" onclick="toggleTab(16392,4)">Art. no.</td> <td id="tab_16392_5" class="px-tab" onclick="toggleTab(16392,5)">Accessories</td> </tr> </tbody></table></div><div class="px-sc-tabbedcontent"><div id="tabcontent_16392_1" class="px-tabbedcontent" style="display: block"><ul>[*]Comes with quick coupling and air hose[*]Double action system for total control[*]Nozzle changing without tool[/list]<p class="bodytext">The SATAgraph 2 spray gun for craft, industry and hobby.</p><p class="bodytext">
Total control
The new SATAgraph™ 2 works according to the double action system for fine controlling of the spray jet. By pressing the trigger you can regulate the air flow and by pulling it further you can regulate the material flow continuously.</p><p class="bodytext">
Flexibility
Is obvious with the SATAgraph™ 2: by simply twisting the spray gun’s Airbrush head about 180° a gravity flow cup system turns into a suction cup system.
Universal
The 0.25 mm nozzle set size is appropriate for all types of Airbrush painting.
Details on the equipment:</p><ul>[*]Airbrush spray gun[*]Aluminium gravity flow cup[*]Plug-in glass cup as well as hose with mini quick coupling and connecting nipple[/list]<p class="bodytext">
</p></div><div id="tabcontent_16392_2" class="px-tabbedcontent" style="display: none"><div id="c15508" class="csc-default"><div class="tx-pxsatalackdatenblaetter-pi1"><!(pistole='1131' OR pistole LIKE '1131%' OR pistole LIKE '%1131%' OR pistole LIKE '%1131') AND tx_pxsatalackdatenblaetter_datenblatt.deleted=0 AND tx_pxsatalackdatenblaetter_datenblatt.hidden=0Arra y()><div id="ldb-datasheet" style="float: left"><! DATASHEET END ></div><script type="text/javascript" src="typo3conf/ext/px_specialcontent/specialcontent.
js"></script></div></div></div><div id="tabcontent_16392_3" class="px-tabbedcontent" style="display: none"><table class="product-techdata"> <tbody> <tr> <td></td> </tr> <tr> <td class="product-techdata-label">Air consumption:</td> <td class="product-techdata-data">10 Nl/min (0,4 cfm)</td> </tr> <tr> <td class="product-techdata-label">Recommended inlet pressure:</td> <td class="product-techdata-data">2,0 <span class="glossaryTooltipLink" onmouseover="glossaryTooltip('599',this);" onmouseout="hideGlossaryTooltip();" onclick="glossaryList(599);">bar</span> (29 psi)</td> </tr> <tr> <td class="product-techdata-label">Maximum operating temperature:</td> <td class="product-techdata-data">50</td> </tr> <tr> <td class="product-techdata-label">Maximum operating overpressure:</td> <td class="product-techdata-data">4 <span class="glossaryTooltipLink" onmouseover="glossaryTooltip('599',this);" onmouseout="hideGlossaryTooltip();" onclick="glossaryList(599);">bar</span> (58 psi)</td> </tr> <tr> <td class="product-techdata-label">Weight:</td> <td class="product-techdata-data">96 g</td> </tr> <tr> <td class="product-techdata-label">Air inlet:</td> <td class="product-techdata-data">Mini quick coupling</td> </tr> <tr> <td class="product-techdata-label">Size:</td> <td class="product-techdata-data">0,20 - 0,25</td> </tr> </tbody></table></div><div id="tabcontent_16392_4" class="px-tabbedcontent" style="display: none"><table class="product-ordernumbers" cellspacing="1" cellpadding="0"> <tbody> <tr class="row_uneven"> <td class="product-ordernumbers-description"> <div style="width: 500px; float: left; clear: none">SATAgraph 2 nozzle 0,25 with cup, miniature coupling and 3 m PVC hose</div> <div style="width: 100px; float: right; clear: none; font-weight: normal">Art. No. 5082</div> </td> </tr> <tr class="row_even"> <td class="product-ordernumbers-description"> <div style="width: 500px; float: left; clear: none">SATAgraph 2 nozzle 0,25, gravity flow cup 4 ml and siphon cup 15 ml, without PVC hose</div> <div style="width: 100px; float: right; clear: none; font-weight: normal">Art. No. 134536</div> </td> </tr> <tr class="row_uneven"> <td class="product-ordernumbers-description"> <div style="width: 500px; float: left; clear: none">SATAgraph 2 nozzle 0,2 mm with cup and miniature coupling</div> <div style="width: 100px; float: right; clear: none; font-weight: normal">Art. No. 123430</div> </td> </tr> <tr class="row_even"> <td class="product-ordernumbers-description"> <div style="width: 500px; float: left; clear: none">Nozzle set 0,20</div> <div style="width: 100px; float: right; clear: none; font-weight: normal">Art. No. 123448</div> </td> </tr> <tr class="row_uneven"> <td class="product-ordernumbers-description"> <div style="width: 500px; float: left; clear: none">Nozzle set 0,25</div> <div style="width: 100px; float: right; clear: none; font-weight: normal">Art. No. 31476</div> </td> </tr> </tbody></table></div><div id="tabcontent_16392_5" class="px-tabbedcontent" style="display: none"><div class="accessory-block-header" onclick="toggleAccessoryBlocks(1);">Important</div><div id="accessoryblock1" class="accessory-block" style="display: block"><div id="pxcb_4205" class="px-cb-block" onmouseover="pxcb_mouseover(this);" onmouseout="pxcb_mouseout(this);" onclick="pxcb_mouseclick('index.php?id=pvcschlauch &L=1')"><table border="0" cellspacing="0" cellpadding="0" width="100%"> <tbody> <tr> <td> <h4>
en::Produkte/produkt.jsp@index=34-a0-001-1-5025.html</h4> <p class="bodytext"></p> </td> </tr> </tbody></table></div><div id="pxcb_4207" class="px-cb-block" onmouseover="pxcb_mouseover(this);" onmouseout="pxcb_mouseout(this);" onclick="pxcb_mouseclick('index.php?id=gewebeschla uch&L=1')"><table border="0" cellspacing="0" cellpadding="0" width="100%"> <tbody> <tr> <td> <h4>
en::Produkte/produkt.jsp@index=34-a0-001-1-5025.html</h4> <p class="bodytext"></p> </td> </tr> </tbody></table></div></div><div class="accessory-block-header" onclick="toggleAccessoryBlocks(2);">Additional</div><div id="accessoryblock2" class="accessory-block" style="display: none"><div id="pxcb_1910" class="px-cb-block" onmouseover="pxcb_mouseover(this);" onmouseout="pxcb_mouseout(this);" onclick="pxcb_mouseclick('index.php?id=hochleistun gsfett&L=1')"><table border="0" cellspacing="0" cellpadding="0" width="100%"> <tbody> <tr> <td> <h4>
en::Produkte/produkt.jsp@index=34-a0-001-1-4817.html</h4> <p class="bodytext"></p> </td> </tr> </tbody></table></div><div id="pxcb_1483" class="px-cb-block" onmouseover="pxcb_mouseover(this);" onmouseout="pxcb_mouseout(this);" onclick="pxcb_mouseclick('index.php?id=1483&L= 1')"><table border="0" cellspacing="0" cellpadding="0" width="100%"> <tbody> <tr> <td> <h4>
SATA® Cleaning Set™</h4> <p class="bodytext">
For efficient spray gun cleaning</p> </td> </tr> </tbody></table></div></div><div class="accessory-block-header" onclick="toggleAccessoryBlocks(3);">Spare parts</div><div id="accessoryblock3" class="accessory-block" style="display: none"><div id="pxcb_1896" class="px-cb-block" onmouseover="pxcb_mouseover(this);" onmouseout="pxcb_mouseout(this);" onclick="pxcb_mouseclick('index.php?id=reparaturse tmcb&L=1')"><table border="0" cellspacing="0" cellpadding="0" width="100%"> <tbody> <tr> <td> <h4>
en::Produkte/produkt.jsp@index=34-a0-001-3-7146.html</h4> <p class="bodytext"></p> </td> </tr> </tbody></table></div><div id="pxcb_4215" class="px-cb-block" onmouseover="pxcb_mouseover(this);" onmouseout="pxcb_mouseout(this);" onclick="pxcb_mouseclick('index.php?id=glasbechers atagraph2&L=1')"><table border="0" cellspacing="0" cellpadding="0" width="100%"> <tbody> <tr> <td> <h4>
en::Produkte/produkt.jsp@index=34-a0-001-1-1638.html</h4> <p class="bodytext"></p> </td> </tr> </tbody></table></div><div id="pxcb_4216" class="px-cb-block" onmouseover="pxcb_mouseover(this);" onmouseout="pxcb_mouseout(this);" onclick="pxcb_mouseclick('index.php?id=5glasbecher satagraph20&L=1')"><table border="0" cellspacing="0" cellpadding="0" width="100%"> <tbody> <tr> <td> <h4>
en::Produkte/produkt.jsp@index=34-a0-001-1-1638.html</h4> <p class="bodytext"></p> </td> </tr> </tbody></table></div></div></div></div><script type="text/javascript" src="typo3conf/ext/px_specialcontent/specialcontent.
js"></script><div id="rightcontentbox"><div id="rightcontent"><form id="language_navi" method="get" action="/index.php?id=satagraph2" style="height: 22px"> <div><input type="hidden" name="id" value="1131" /> <select onchange="document.forms['language_navi'].submit();" style="width: 80px" name="L"> <option value="0">deutsch</option> <option value="9">czech</option> <option value="1" selected="selected">english</option> <option value="12">english (cdn)</option> <option value="11">english (us)</option> <option value="2">espanol</option> <option value="3">francais</option> <option value="4">italiano</option> <option value="18">magyar</option> <option value="6">polski</option> <option value="7">русский</option> <option value="8">*文 - chinese</option> <option value="5">한*어 - korean</option> </select></div></form><div class="px_right_top_margin" style="height: 54px"></div><div id="c14041" class="csc-default"><div class="csc-textpic csc-textpic-center csc-textpic-below"><div class="csc-textpic-imagewrap csc-textpic-single-image" style="width: 206px">
</div></div></div></div></div>
