RE: fa 80 (older)
To check cam timing on an assembled engine
Remove the valve covers
Find top dead center on the compression stroke
Rotate the prop 360 degrees and both valves should be partially open - one closing and one opening. You can look across the tops of the rocker arms and they should be parallel with each other
