RCU Forums - View Single Post - Prop Phasing
Thread: Prop Phasing
Old 07-25-2003 | 02:59 AM
Spicoli
Default Prop Phasing
Hobbsy,
I don't mean to offend you but you are wrong.Dave Gierke can explain it better than me but I will try.
Okay,assume you have an engine that vibrates more than it should because the counterbalance on the crankshaft is not heavy enough.[common problem on older engines]
This is what you do,
1 make sure piston is at top dead center
2 put on a unbalanced prop, heavy blade down
That is it ,pretty simple.
