RCU Forums - View Single Post - Prop Phasing
Thread: Prop Phasing
Old 07-27-2003 | 03:25 AM
downunder-RCU
Default Prop Phasing
hobbsy....I see what you're getting at. If two blades weigh exactly the same then to be in balance they must have the CG for both of them located at exactly the same distance out from the root. With the single blade example the CG of the counterweight is probably about 1/2" out from the crank centre line while the much lighter prop blade is maybe 3 or 4 times further out.
