RE: 4 cycle lubrication
The valve lash is properly adjusted. I even took the rocker arms off and cranked it over several times. I could hear the air leaking through the muffler.
I plugged the exhaust and the compression was much better. I heard no leakage through the intake so I know the problem is limited to the exhaust valve.
