RE: Balsa USA Super Cub Build
Regarding the cabin top structure, am guessing most used the included brass tubes? Have considered maybe drilling foils out a bit larger and using carbon instead. Seems that it might get a bit tight running servos and lights thru 1/4". Any thoughts? Has brass looked like going to work ok or did you or would you have done it different?
HM
