RCU Forums - View Single Post - aileron question
Old 07-19-2010 | 07:21 PM
j.duncker's Avatar
j.duncker
Default RE: aileron question
If you want to learn about using the facilities in your 9c tx then setting up to use two seperate servos on two channels is a good place to start as it will be a common thing to do in the future.
The procedure is described in the section of the manual starting on page 44. HINT You have to select the flaperon option to start with.
Additional help here [link=http://www.futaba-rc.com/faq/faq-9c.html]CLICKY[/link]
