RCU Forums - View Single Post - CMP 120 Zero ARF Build thread
Old 07-20-2010 | 08:59 AM
  #269
ZERO-322
Default RE: CMP 120 Zero ARF Build thread
my experience is it pretty close to were it should be however you may want to tweak it a little bit, I think I balanced mine at 135 mm from the LE , did you install the older or newer rear carb version of the CRRC , please make sure you post some pic of your work
