RE: flaps on left slider <> servo arm position ?
Thanks for your piece of advice
I will then set the slider neutral at the mid-point (and the servo arm perpendicular)
The only drawback is not being able during the flight to easily come back to the neutral position (it is not easy sometimes to hear the beep of the neutral position when there are noisy glow engines around)
