RCU Forums - View Single Post - Repairing wheel pants
Old 07-20-2010 | 04:49 PM
opjose's Avatar
opjose
Default RE: Repairing wheel pants
It's almost trivial to repair cracked pants, if you put a little effort into it.
Here goes:
- Remove the wheel pants
- Tape the outer part of the pants together tightly with masking tape.
+ You can save some sanding later if you have minor cracks, if you put wax paper over the outer crack, to shape any epoxy that may seep through.
- Cut several strips of fiberglass cloth, that you can lay on the inside of the cracked wheel pant. You want to minimize the number used at one time.
- Mix up some 30 minute epoxy, and add about 30% Isoprophyl Alchohol to it to thin the mix. Some people use Acetone, but this may ruin paint.
- Apply the thinned mixture with a brush to the inside.
- With a gloved hand, lay the fiberglass strips to the inside of the pants.
- Apply more thinned mixture until the fiberglass seems to all but disappear.
- It is OK if the fiberglass extends beyond the wheel opening, as you can cut or sand off the excess easily later.
- Let dry overnight, preferably inverted.
- Repeat if desired but I find two fiberglass strips are often more than enough...
- Remove the tape and wax paper.
- Now for the outside you have your choice, you can apply epoxy and filler, or use something like Bondo.
- Apply the Bondo, let dry, and sand the pants with progressive grits of sandpaper until somewhat smooth.
- Clean, prime & paint.
Done.
BTW: The same works for cowls too. I have repaired HUGE holes in cowls or remodified the cowls for completely different engines and mufflers this way.
