RE: Aeroworks Yak54 50cc build issues
Forgot to say, that the fuel tank and batteries were moving around when engine was run so I strapped them down really good, especially the fuel tank velcros. I decided to use the velcros instead of zip ties because I wanted to remove the tank fast for CG purposes, etc. I would have to cut zip ties on tank plus vent line everytime I wanted to adjust something. The tank sits on top of the rubber foam padding, not the soft kind for Rx but the hard kind and it's causing the tank to move forward before I strapped it down really good. I mean pushing on the tank from top, compressing the tank and the hard rubber padding under it. Now the tank doesn't move, the batts. are fine as well.
