RE: Engine Running in Reverse
If the engine is running backwards, first try rapidly pushing the throttle open. The engine will either sputter and then turn around, or it will sputter and die. If that doesn't work, and the fuel line is accessible, pinch the fuel line off while the engine is running backwards. Again, the engine will reach a point where it will turn around or it will burn off the over prime.
Brad
