RCU Forums - View Single Post - flight box battery
Old 07-21-2010 | 08:22 AM
landeck
Default RE: flight box battery
18 volts is way too much for a glow plug. You need to run it through a glow driver such as seen on starter panels which drops the voltage down and limits the current. 1.2 to 1.5 volts is what should be used if you connect the battery directly to the glow plug. This can be supplied by a single cell NiCad, NiMh, or an Alkaline battery.
Bruce
