RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 07-21-2010 | 04:44 PM
  #2787
MikeMayberry's Avatar
MikeMayberry
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: chocorrol
hi guys, I have some more questions... first, can someone explain me how the C and S functions works? I know the C means combination and the S means separately but does it mean that if I put the S on one function it wont work if I have some other C functions on? does it mean that every time that I turn on a C function, all the C functions will turn on automatically?
my next question.. what the T.App function does? I see it on all mixes but I can't see in the manual what it exactly does...
I also would like to know what the adjust to trim function does... I have only seen that on the throttle cut menu.
I'm sorry if my questions are too silly but I really want to know how it works
S means that the mix or setting will be unique for that flight condition. Yes, if "C" is selected it will stay that way in all condition unless changed. Adjusting the setting in one condition will also affect them all.
T.App is Trim Apply. I would have preferred that this was defaulted to on but since it is not you will have to activate this so that the trims are the same in all conditions. In some cases you will want to have separate trims so you would leave this inhibited.
Adjust to trim allows you to use the trims to adjust the setting when the function is active instead of going into the menus to set it. I always use this feature with the idle down and cut functions.
Mike.
