ORIGINAL: BaldEagel
I know this is not helpful, but may be useful to others, transfer all your models into the INTERNAL memory before carrying out this upgrade, the memory card seems to be formated when you down load the update, the internal memory is not affected by the download.
Mike
Mike, that is not correct. The CF memory card is not formatted again. At least not in mine
It would be interesting however, to check if the model data of both the internal memory AND the CF-card have been upgraded in the process ?
Can someone check that for me please ? (I do not have my 14MZ on hand).
If this is not the case, it means you should first copy everything into the internal memory, then make the upgrade, and then copy model data back to the CF-card (and from there, make a valid back-up to the harddisk of your PC).
Nicolas.
