RE: Covering Help
What are you using to cover with?? Monokote or Ultracoat?
I ask because your choices for covering this will depend on what you use if you use Monokote then we can use the Windex Method to lay down your trim colors. If you are using Ultracoat you can't use that method.
Ken</p>
