RE: OS 95 AX
ok i got my plane back together and tuned it on the stand tonight ,i did the pinch test,and then i held the plane up ,down ,sideways and level and it ran perfect never choked or gurgled one time ! So tomorrow nite i plan on doing the same with the cowl on and see how it runs. is there anything else i should check before takeing it up again and if its going to get too hot in the cowl will it do it on the ground the same as it would in the air?
