RE: Is it really necessary to pin nylon or CA hinges?
With the nylon hinges I pin them because there is the worry of not getting the mechanical joint like you should. The thing is though that the glue in both hinge types is much stronger than the holding power of any pin, so unless the glue breaks loose the pin is completely unneeded.
