RCU Forums - View Single Post - Heavy verses medium classification.
Old 07-23-2010 | 02:43 AM
RSEA's Avatar
RSEA
Default RE: Heavy verses medium classification.
For installation I very closely followed the instructions laid out by Monotheist in the following thread:
http://www.rcuniverse.com/forum/m_89...tm.htm#9000272
I believe he was the first to install one of these devices in a Tamiya tank..
I could not get the tank to have equal amounts of delay for stopping and starting in BOTH forward and reverse directions no matter how I adjusted the pots. The runaway full throttle happened while going in reverse, right after changing direction from forward to reverse. It may have been from changing direction too fast with the stick and the delay response getting backlogged by the Turnigy, I don't know. I do know that the runaway condition promptly ceased after removing the Turnigy and has never re-occurred since I took it out of the tank. Each time the runaway occurred centering the throttle stick would NOT stop the tank, I had to power off the radio to get it to stop moving. I only experienced that problem when the Turnigy was installed.
My radio is a 75Mhz Polk Tracker III, controlling a 75Mhz, 8 channel, dual conversion, FM Futaba receiver installed in the tank.
