RCU Forums - View Single Post - RCG 26cc
Thread: RCG 26cc
Old 07-23-2010 | 10:26 AM
  #57
ahicks
Default RE: RCG 26cc
ORIGINAL: Andrew_S
ahicks, I'm curious, does your aerovate 26 have an actual walbro brand carb? Mine is supposed to but it doesnt...MIne says hilo or something like that on it....I have had starting problems since day one......
The HiLo refers to the adjusting screws, which is which, high speed vs. low speed. The Lo will be the one closest to the cylinder. I believe the carb Id is on the opposite side of the carb?
If it's starting hard, and it has fuel to the carb, it's likely lean. If it hasn't run in a few days, drawing fuel into the carb can be a bear. I don't know what to tell you there. Mine has done that. When I was pretty frustrated one day, I put maybe half a teaspoon of fuel into the exhaust while holding the plane inverted, then rocked it to let the fuel into the cylinder to prime it. Worked like a charm...
Honestly, I'd have to guess it's not a Walbro, but would have to pull the cowl to see for sure. -Al
