RCU Forums - View Single Post - JetJoe OWNERS thread
Old 07-23-2010 | 02:09 PM
  #2963
KJ-66
Default RE: JetJoe OWNERS thread
Hi Guys.
Has anyone of you used the Jet Joe balancer and has successful results with it? I`ve got the JJ 1800 and stripped it down completely,to find out why it had an internal fuel leak. I decided to improve the engine a little and build a new combustion chamber for it. I just completed the press tooling,to make the end caps on the combustion chamber and will press them out,from a stainless steel sheet,tig weld the whole assembly together and see how it works. The shaft assembly will also be replaced with a new one,which is ground between centers - thats why I asked the question about the balancer? I also changed the preload system in the shaft tunnel,as I don`t like the o-ring system.
Any suggestions concerning the balancer will be much appreciated.
Regards
Craig
