RCU Forums - View Single Post - Don's Pershing Build
Thread
07-24-2010 | 12:11 AM
9
torpedochief
Dec 2008
1,842
Charleston, SC
RE: Don's Pershing Build
I made the shell ejection hatch operational.
I pryed the fitting off the turret. Using very small drill bits I drilled out the corners of the the hinges. I also drilled a hole through the hinge to accept the pivot.
With a #11 Blade I scored the plastic until the hatch sperated from the hinge.
A bit of clean up with a file, and Iused a bit of wire to act as a pin.
The purpose of doing this was to provide a placetoputthe switch forthe high voltage flash and sound unit.
To keep the hatch shut I recessed a small area just forward of the opening and CA'd a small Rare Earth magnet.
With a grinding bit in the Dremel, I hollowed out a small depression in the hatch. I changed over to a cut off wheel in the Moto-Tool and cut the tip off of an old Tiger metal axel. This was then CD'd intoplace so that the magnet would catch the hatch and hold it shut.
Don
Reply
Like
torpedochief
View Public Profile
Send a private message to torpedochief
Visit torpedochief's homepage!
Find More Posts by torpedochief
View iTrader Profile
