Hey folks, I've been testing the lower hull of my Pershing and every thing seems to function as normal except.......
Cannon sounds
Machine gun fire
Forward
Turn L/R
Axis Pivot
Reverse <span style="color: rgb(255, 0, 0); "><span style="font-size: xx-large; "><span style="color: rgb(255, 0, 0); ">
?</span></span></span>
http://www.youtube.com/watch?v=ozZ7JEXgBOU
My concern is in the very abrupt halt at the end of the reverse travel. Unlike forward motion, if I center the stick it smoothly stops. When the same movement is tried with reverse, it stops as if it locked gears. The only way I have been able to prevent it, is to ever so slightly return the gimble to the centerposition.
Do I have my transmitter set wrong? Is there a tweaking I can do in the control board?
I do have a Turnigy chip installed, this hasn't helped anything but greatly reduce the halt of the forward and reverse...but the reverse still comes to ascreechinghalt.....just takes longer for it to happen.
Thanks guys for any help!<br type="_moz" />
