RCU Forums - View Single Post - Sig Mid Star 40 Build Thread
Old 07-24-2010 | 06:23 PM
Sukhoi_Madness's Avatar
Sukhoi_Madness
Default RE: Sig Mid Star 40 Build Thread
I installed the first aileron servo into the wing today.
Started by marking out where the servo will sit exactly relative to the servo bay – you’ll note the substantial grasp I have on technical drawing in the first photo.
Then once I’d cut out a slot for the control horn it was a standard setup with hardwood standoffs to mount the servo and 4 servo screws to mount the cover.
I finished off by adding a drop or two of thin CA to all the screw holes.
I’m pleased with how this has come out – it’s not a complicated modification but it’s always rewarding to get a good result. I’d say I’ve built more strength into the area than is required, meaning more weight but not enough to be detrimental I shouldn’t think – and so the strength can only be an upside.
ID:	1472876   Click image for larger version
ID:	1472877   Click image for larger version
ID:	1472878   Click image for larger version
ID:	1472879   Click image for larger version
ID:	1472880   Click image for larger version
