Thanks Jimmy, those will help alot if not fix the issue! Your the man!
Also, here's a thread where I self modified the DX5E making the lever from styrene.<a href="http://www.rcuniverse.com/forum/m_9691275/mpage_1/key_/tm.htm">
http://www.rcuniverse.com/forum/m_96..._1/key_/tm.htm
</a>
But, I'll be sending Joe the actual lever and adjustable screw/hook....just needs to get a spring for it since I can no longer find it.
Eric, I wish the DX6i were that easy. I have the right stick set to control both throttle and turning and I have to set the throttle trim back a bit, if not it continues to rev the tank.....but, Jimmy's links will correct this I'm sure.
