RE: MVVS 58 prosport
Pe
Thanks for your input
guilty as charged I have a tee to a stopper fill valve, I will do away with that
Felt clunk, tygon tube wire locked already
on the 58 ignition pack s std I think, I thought you could change the igntiion for normal silencer or long silencer hence why i went with the long set up
I will check the filter in carb
I have a friend who can do the pressure test
So a bit to do
24x10 wood ok for prop ie not over proped?
will let you know how I get on
thanks
Ian</p>
