RCU Forums - View Single Post - INCREASING CC OF A TWO STROKE ENGINE!!!!!!!!!!!
Old 07-28-2010 | 05:05 PM
pe reivers
Default RE: INCREASING CC OF A TWO STROKE ENGINE!!!!!!!!!!!
If you can find the cylinder piston/wrist pin that fits crank case and connecting rod, go for it, but don't aim fo more rpm. Displacement is torque. With higher rpm you are liable to run into vibration problems if the piston is heavier.
