RE: Vanquish I vs. Vanquish II
Just had to tell you guys how happy I am with the MkII. I didn't use the servos nor the motor suggested, but found also through HobbyKing some parts that saved me over $100. You need to check out the servos that I'm using as they are just a little larger than the suggested ones but check out the specs3.0. I can't remember when I had a plane that set up for landings any better than my MkII. I just got another battery that is a 4s 3.0amp that has up to a 50C rating. The only problem that I have understanding electrics is the 40 amp ESC I'm using, is it able to allow me to use all of this power. I have a new 60amp ESC to replace the 40 one, but should I use a larger prop to get more pull? The Watt meter while using an APC 12x8 shows only 300 Watts at 28 amps. Here is the [link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2098]motor[/link] I'm using. Anyone know the answer please let me know.
[link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6608]SERVOS[/link]
