RCU Forums - View Single Post - RCG 26cc
Thread: RCG 26cc
Old 07-28-2010 | 08:22 PM
  #60
ahicks
Default RE: RCG 26cc
I'll tell you how I fixed it. I pulled the prop hub off and ran a bolt out through the front of it from the inside. It's all set up for it. I couldn't stand the wobble of the prop bolt in the loose threads. This fixed that issue too. No more drill jig or potential weakened props! One caution if you're going to try this. You need to grind the head of the bolt down, by maybe a third. Otherwise, it contacts the end of the crank about .030 prior to the hub seating completely. No big deal as long as you're prepared for that to happen. No problems since, with over 2 gallons through it.
