RE: da-100
Never had a DA for it to do it, but have had a Zenoah 62 to do it with a prop strike.
One way you can tell is to look in the exhaust port and turn the engine over until you see the piston get to the bottom of the port and then look and see if the other piston is in the same location, plus if it is out bad there will be a hard spot when trying to turn the engine over.
