ORIGINAL: lemondspud1
I am new to electric i purchased a plane that needs a reciever and battery I understand everything except how the on and off switch hooks up the speed control has the three leads for the motor and the lead for the battery and the lead that hooks up to the reciever and i was wondering how the switch hooks up i dont understand because the battery lead is already connected to the speed control PLEASEHELP
Ithink you have about 3 sentences tied together there without punctuation. So I am not 100% sure what you are asking but I am going to take a guess.
Not all ESChave on/off switches. The ones I have seen have them prewired so there is nothing to hook-up. They are already connected.
3 heavy wires go to the motor
2 heavy wired go to battery
Small wires with servo type plug goes to your throttle channel on the receiver. Which one depends on your radio.
Switch normally only disables the motor, but does not cut power to the ESC. If you leave the battery connected it will be drained by the ESC even though the switch is off. This will ruin a lipo battery.
What do your instructions way?
Since I don't know what plane you puchased I can't tell you any more. Can you post a link to info about the plane?
