RE: RCG 26cc
You are correct. I have no problems with it. I have 3 planes set up that way. After the first few flights the bolt has stayed tight. It is no different that running a Saito 180 or other big bore. The backplate has the knurl on it to keep a positive drive engagement on the prop.
