RE: tire problem!!
<span style="font-family: Arial"><span style="font-size: larger">Hi all, i've had my MTA-4 (which is the exact same truck as the MGT) for 2 yrs now & i had that prob too. I fixed it by buying 23mm hex adapters & 40 series rims & tires, WOW what a performance & handling improvement they made. The stock rims i sent back to Thunder Tiger & was sent a brand new set (6 months later), but i haven't used them as i had fitted the 23mm hex-40's with Big Joe's on . So if anyone out there wants to buy the stockers i'd be glad to sell them as i don't have any other cars with that size hex's. Haven't had any tire prob's since. & it hammers with an O.S. VG.30 & Side mounted Novarossi pipe fitted with the option side mount header. Awsome truck. It blitzes most buggy's around the track. Handles unreal, just wants to wheelstand all the time is the only prob at times, ( i don't mind that one little bit ! ) Try the 23mm hex setup !!!! You won't look back man.</span></span>
