RCU Forums - View Single Post - Needs help
Thread: Needs help
Old 07-29-2010 | 06:51 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Needs help
Making a similar attempt at helping here....
If your radio came with a little switch harness, you may not need it. Most small electrics are powered up by hooking up the battery to the speed controller. The recever gets its power, as Ed said, through the lead that plugs into the throttle channel.
There's other installations but this is the most common for the smaller electric stuff.
