Slow roll aileron rate
Hi all. Those of you that can do the sweet horizon to horizon slow rolls, are you using a low aileron rate and pushing the stick all the way to the stop, or are you skilled enough to maintain constant roll rate while feeding in elevator when inverted?
Since my slow rolls tend to start out slow and then speed up at the end, I'm thinking of putting a super low aileron rate on a switch so I can just push the stick to the stop.
Thoughts???
