RCU Forums - View Single Post - MVVS 58 prosport
Old 07-30-2010 | 12:54 PM
pe reivers
Default RE: MVVS 58 prosport
I suggest you try a crankcase pressure test first.
When you blow in the carb pulse line, there should be no air leaks in the front bearing area (piston halfway up), The reeds should close up fairly well. The engine pumps harder than you can blow, so with running engine they will close completely.
