RE: TFGE F4U Corsair 60 Kit Build
Tracey,
Thanks for the kind words. Normally with this build one would have the flap servo's mounted in the same direction. I took one of the servos and turned it 180 so each servo arm is opposit of each other, putting my actuating arms at the outer section of the inboard flap. Since I didn't have a reversing "Y" harness and I had the matchbox sitting around, read the direction and found out I could reverse one channel while running the other normally. I'm still running off of ch 6 with one lead from the receiver to the matchbox. The setup is working and didn't add but 1/3rd of an ounce of weight. Great question Tracey, if you have any more please feel free to ask.
