ORIGINAL: fxstb
Hi, can you tell me what are the dimensions of the cowl and also the recommanded distance from the firewall to the prop hub.
Thank you
Hi.
The diameter of the cowling is 200mm.
The prop hub is set 130mm from the fire wall.
Hope this helps.
