RE: pro mod homelite /
I am not understanding your response real well but am of the opinion as follows. (much the same as Mike I think)
Use crankcase fitting to work water pump. If your carb does not use an external pulse fitting (some carbs do - though not many) then block off the fitting from the iso block. I would avoid using a Tee fitting to join two pulse fittings.
