RE: Low end needle question
I think the carb idle circuit controls the fuel flow through much of the lower RPMs. Since the problem has just recently started, I would check the idle paths for dirt, including the idle needle jet. Look at the flow diagram for the particular carb you have and you can see the fuel flow at different butterfly openings.
Regards,
Richard
