RCU Forums - View Single Post - BH AT-6 Texan Build
Old 08-01-2010 | 09:08 AM
  #34
fxstb
Default RE: BH AT-6 Texan Build
ORIGINAL: Pennbrit
ORIGINAL: fxstb
Hi, can you tell me what are the dimensions of the cowl and also the recommanded distance from the firewall to the prop hub.
Thank you
Hi.
The diameter of the cowling is 200mm.
The prop hub is set 130mm from the fire wall.
Hope this helps.
Yes, thank you. All the specs of that plane are very similar with the World Models (Airborne distr.) AT-6. I had a RCGF 20cc in it and it fitted well except that at the second flight, at take off (60 feets in the air), the engine stop for no raison to be found. You have to know that the AT-6 fly like a rock with not enough air speed.
Yves
