RE: HYDEOUT
Bipeflr,
Keep in mind, you dont want to set your CG based on this. You want the CG based on all the other trimming factors and this will help eliminate any pitch mixes. If the plane needs more down than you like, check your expo settings. If you have a lot of expo, take some of it out only one the down side. I personally run a little more down elevator, and actually a little expo to make it more sensitive inverted so that I can run a forward CG which helps eliminate any pitch mixes as well as makes it lock lines better than an aft CG. If the other parts of the trimming ideas tell you the CG is OK, then adjust your rates/expo to get the feel you want.
Arch
