RCU Forums - View Single Post - DX7 Binding issues with eletric plane
Old 08-02-2010 | 07:28 AM
Steve Percifield's Avatar
Steve Percifield
My Feedback: (14)
Default RE: DX7 Binding issues with eletric plane
LDM,
Your procedure is correct. Transmitter first, then receiver. And shut down is correct, reciver , then transmitter.
After you have your plane setup and operating, re bind the receiver again. Same as initial startup , with plug, etc.
Also, we have found that if the transmitter is around or setting on metal, it will not bind. Such as metal bleachers or a metal lawn chair. Get it away from the metal and no problems.
Thos are a couple of things we have discovered. But, rebinding has solved your problem here.
steve
