RCU Forums - View Single Post - Engine problem?
Old 08-02-2010 | 07:36 AM
abufletcher's Avatar
abufletcher
Default Engine problem?
I have an RCV91cd that I've been flying for some time now (after getting it back from repairs from the UK). It's really been running very well, starts easily, good high end (about 9200) and idle (about 2400) and never had a deadstick. But last week that changed. I'm not sure what happened. It still starts easily but it won't rev about 6000 and if I open the throttle wide it dies. Also telling is that adjusting the needle doesn't do anything. It seems to be running lean, though.
A mate suggested there might be some junk or grim in the carb so I flushed that out with an alcohol-based parts clearer spray, but that didn't solve the problem. On the test stand, I started the engine with the needle about three turns out but even at this rich setting I wasn't getting much smoke. And as I screwed the needle in there was no change in the RMPs until finally the fuel was cut off and the end stopped. In short, adjusting the needle valve doesn't seem to do anything at all.
What's happening here?
