RCU Forums - View Single Post - Twin Otter Stab Mod
Old 08-02-2010 | 09:03 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Twin Otter Stab Mod
I'm not exactly sure what you're thinking of doing. If the stab is very thin, you won't have room for a 1/4" tube.
I would remove the LE, drill a horizontal hole throught the vertical fin and replace the LE with a CF tube the same diameter as the thickness of the stab (If the stab is 1/4" thick, use a 1/4" tube) then use filler to get the shape back and re-cover with black (The black may have to extend slightly further aft than it does now to hide the work)
