RE: Going CL with tis R/C model
If you plan flying this model in competition look at the AMA rules carefully, they have changed the line diameters and they have also changed the minimum line length, anything above 8 lbs needs to fly on 65'-70' lines. if you are under 8 lbs the lines can between 52.5' and 70 feet.
